;help1992 lt1 6 speed. When I run the air conditioning my belt squeaks. I have replaced the belt and idler pulley. If I rev it up a couple of times it stops. Air blows ice cold. Any ideas?
Spray belt with dry spray deodorant,wont effect the belt rubber like WD 40 or CRCSilicone spray works better than wd-40 try that, if not, then a new belt.
Okay guys..now you have lost me with the WD40 spraying on the belt. Wont that cause the belt to slip????? I have a squealling also but only after the engine has warmed up to running temp. Fine when its cold...
1990 Vert..(L98).
Inform me please!!!!!
