ptuner11
I just replaced the front bushings and kingpins in my 60 and some of them squeak. My thought was that they are not getting greased. I've removed the grease fittings and check for grease flowing through them. It all looks good to me. Is there something else i could do to stop the squeaks?
thanks
JohnZ,
re: leaking water pump..... I reinstalled the frame plate and the water pump, this time with a dowel pin thru the plate and into the block to keep it all straight. so far so good. thanks again for the idea!
thanks
JohnZ,
