Both Fel-Pro and Loctite make an N5000 anti-seize.
From the Fel-Pro site:
"TYPICAL APPLICATIONS
· Bolts, studs, valves, pipe fittings, slip fits and press fits in
nuclear electric power generating plants, chemical plants,
pharmaceutical plants, paper mills and other locations
where stainless steel fasteners are used.
Operational Benefits:
· During assembly - prevents high friction, galling and
seizing.
· Promotes uniform and predictable clamping.
· During operation - high purity prevents stress corrosion
· Disassembly - prevents seizing, galling, destruction of
threads
DIRECTIONS FOR USE
1. Before or during assembly, wipe brush onto threads and
other joint surfaces needing protection.
2. Use full strength. Do not thin."
I'd been told it contained Molybdenum, but the MSDS sheet says it does not. I've had very good luck with it. It's pricey at $45 for 8 ounces, but 8 ounces will last years and it never deteriorates.
