B
bdisanto
Still not driving!! the car will start, idles for 10 minutes +/- than just stalls when I do get it on the road it will run ok, than stall at 40-50 mph, starts back up and runs ok until it stalls again.
I have changed the fuel filter, fuel pump, fuel pump relay, alternator, belt, both MAF relays, starter enable relay, starter,all three cats, y pipe, both mufflers, air & oil filter, plugs, wire, rotor and cap.
Yesterday I removed the plenum, checked the EGR vavle, all vacuum lines, cleaned the IAC, sprayed all connections with contact cleaner.
Started the car it idled for about 15 minutes and stalled, started right back up, took it for a ride went about 10 miles stalled at 45 mph, started right back up, turned around and went home. I also noticed that it would not go into overdrive when I pressed the shift button?
There are no codes
Any help would be appreciated!
THANKS
Ben
There are no codes
THANKS
Ben
