D
Doutdoor
One Saturday evening I went into my garage to start the car and click-click-click and then it started but the starter motor kept running. I turned the motor off but the starter kept running so I flipped the key back on to turn the engine back on. Then I disconnected the negative battery terminal to turn everything off. The next day I called around and got a price on a rebuilt starter from Autozone. Took the old original starter out and installed the rebuilt one. When starting the engine, it sounded terrible. Kind of like a grindy, it's not properly engaging type of sound. I checked the rebuilt starter with the old one before I installed it and they looked identical. Anyway, I figured that I probably should not have bought a rebuilt unit, so I just bought a brand new Hitachi high torque permanent magnet starter for Chevrolet applications with 153 or 168 tooth flywheels. I asked the guy before I bought it if it would work in a 92 Corvette and he said yes (as I have no idea how many teeth on the flywheel in the car). I installed the Hitachi starter but it sounds worse than the rebuilt one I just removed.
Is there a chance the teeth on the flywheel are tweaked because of the problem with the original starter. Or, am I just running into bad luck with these starters? I did look at the teeth on the flywheel through the opening in the cover pan on the botom of the transmission and they looked ok. I didn't take the cover off though to inspect the entire flywheel and I suspect I'll probably have to do this. Any help would be appreciated. I've never had a problem like this with a starter.
Thanks,
Dave
Thanks,
Dave
