Thanks John....I can't help but thinking my problem is in the wiring to the starter. When the 73 is hot, the car turns over fine but when you LET OFF on the key, it wants to catch and start. The starter, coil, plugs, wires are new. I even got rid of the points and condenser and put in an after market ignition in the distributor and had the carb rebuilt and had a spacer put on between the intake and carb to keep some of the heat away from it. I just bought a starter blanket (haven't put it on yet)to keep some of the heat away from it also....Any ideas on what to do next...........Thaks John...you seem to know what your talking about. Barry McIntyre
