aebcpama
This past weekend when I started my 2000 C5 with 36000 miles the starter would not disengage.
Even when I turned the key off if kept cranking. When I ran for a wrench to disconnect the battery
it finally let go. I waited an hour before trying to restart it and it happened again. This time when I revved it up a little it let go. I drove home and parked it.
At first I was thinking it needed a new solenoid but after asking some mechanics they are thinking
maybe the ignition switch or the starter relay? Is the starter relay also known as the TDR( theft deterrent relay)? Before I tear into this I wondered if anyone else has experienced this problem?
Thanks!
Thanks!
