To: rockytoptilidie
Hiya!
I don't think that I ever managed to button down exactly what was causing the fault. I changed the starter motor, the battery and the starter motor switch (see Joel's posts).
I checked out the fuses, Park/Neutral switch, ignition barrel and VATS resistance module (unplugged the lead from the ignition barrel and bridged the connector with the relevant resistance).
I believe that it may have been a combination of things and I think that I have just found something else...
Having changed the starter and battery, for a couple of days the car would start immediately I turned the key. After that, it seemed to turn over for a long time before firing up. A couple of days ago, the same old fault came back!! All lights on, everything working, but nothing happening when the key is turned to start!
In deseperation, I used a set of jump-leads off of a friends car - and the 'Vette started like a dream!! The only difference was that I connected the positive lead to the battery and the negative lead directly to a bracket on the block.
I now think that I may have a damaged/loose earth connection somewhere - possibly the main one to the block (although I cannot seem to find where it attaches - any ideas?)
Since then, it hasn't happened again but I now carry a set of leads with me and if/when it happens again, I'm going to connect the negative terminal of the battery directly to the block and see if that cures it. If it does - problem solved! If not, I guess I'll be back here again asking for help!
I hope this helps.
Nige.
To be continued.........?
