Jim Martley
- Joined
- Jan 10, 2003
- Messages
- 48
- Location
- Slingerlands, N.Y.
- Corvette
- 1982 Red ,93 Yellow,93 Brt. Aqua
Monday morning I went to drive the car to work and it would just crank over and not run. When I came home from work in the afternoon I tried it again with the same results. I checked the ECM & the CCM for codes and got none. I checked for fuel pressure and it was at 40psi. I checked for spark at the coil and had plenty. I checked for injector pulse and tha was fine. I started to notice that the engine would try to run backward if I didn't turn the key to the off position after cranking it a few times. Out of desperation I condemed the optispark and ordered a new MSD unit from Summit Racing. It came in yesterday and I installed it. I test fired the car after installing just the new opti and it started right up
! I proceded to struggle putting the rest of the stuff back on the front of the engine and filled the cooling system. I went to start it up and now it is acting like it did before
. I checked to see if I pinched a wire or something stupid like that and found no reason for the change.
The engine acts like the timing is severly retarded. I also don't hear the "spark knock" sound that I usually hear when a LT1 is cranking over.
Anybody have any suggestions?
