Starts - Won't Start - Starts - Won't Start
glen3107
Atascocita, Texas
1987 Black Coupe
I bought my 1987 Coupe about 3 months ago with 80K on the odometer. It's the car that I dreamed about for years. I've been driving it every chance that I get.
When I bought the car, the trim on the driver's side was loose. The former owner had ordered a trim piece but had not installed it. About a week ago, I drove the car to work and it sat in the sun during the day. When I got in the car, I noticed silicone dripping down the door, (where he had glued the trim and tried to repair where he had broken the top of the door interior).
This weekend, I took the door off, replaced the trim and repaired the broken plastic.
Up to this time, the car started everytime I turned the key.
Since I repaired the door, sometimes it will start, other times it just sits there. When it won't start; I turn the key - the dash lights; radio, blower, etc all work, but the starter does not turn, not even a click. The battery is fully charged. The strange part is that I can leave the car and come back in 5 to 10 minutes and it starts right up.
I've heard stories about the security system not allowing the car to start. Can you'all help?
John
S
Shadowing1985v
corvettes are really smart cars
so much safty stuff on it, and stuff like that
i didn't think 87's had anythin like that
i think in the 90's they started making the security systems that are really touchign to mess with
B
Bullitt
Welcome to the forum John. There's a few of us that live in the Houston area, too. :)
It's been awhile since I've had to battle with the VATS system. I can't remember if it shuts down the electronics completely, including dash lights, etc. I do remember however, that it took longer than 5-10 minutes for the system to reset itself. I'd be out 30min. to an hour. :( Hopefully, someone will come along who knows the system more intimately.
--Bullitt
glen3107
Atascocita, Texas
1987 Black Coupe
My wife just reminded me that it may have been more like 20-30 minutes, rather than 5-10.
Ken
Gone but not forgotten
Hermosa Beach, CA
1987 Z51 Silver Coupe
I have no more to offer on this subject that hasn't already been covered many times, except to say "Welcome to the wonderful world of the intermittent no-start!" :eyerole
glen3107
Atascocita, Texas
1987 Black Coupe
Thanks Ken,
I'm sorry to hear that I'm not alone. I did a search on previous "intermittent no-start" discussions.
Guess I'll start working down the list of possible problems.
I wonder if I did something when I removed the door trim. Is there a sensor that I may have moved or something?
John
vigman
Motor head!!!!
Valencia, CA,USA
Find my posts on VATS
Read those and we will chat!
Vig!
vigman
Motor head!!!!
Valencia, CA,USA
VATS Primmer
On the Key is a pellet.
The Pellet is a presision resistor.
There are 2 fingers in the key switch housing which contact the pellet.
87 I believe was the first year of VATS
Vehicle Anti Theft System
IF the resistor( key ) doesnt match the on board value in the VATS box, it interrupts the starter circut via a relay ( hidden behind the panel where the "Check Engine" light lives.
Refered to as the DIC panel
Drivers Information Console.
87 had a different style key pellet than later years, the NEW key pellet had a larger contact area.
So there are a few ways to fix this.... ( read posts )
AND
If the Key misreads... the VATS will reset in 5 minutes IF no attempts to start or KEY in have occoured during that time.
Make sure the pellet is clean ( Shiny metal )
and you do not have a BILLION KEYS ON THE RING for weight.
A quick fix is to have a NEW key made with the NEW style pellet ( IF THE WORN PELLET IS THE PROBLEM)
The other problem is the fingers get dirty and or loose spring tension.
The BAD problem is when one of the TINY wires off the switch assy either,
A) Break off
B) Insulation chaffes and one side of the circut is pulled to ground.
This pair of wires runs down the steerring column and surfaces under the dash ( You have to remove the HUSH panel to get at it.
Vig!
jsinga
Savannah, GA, USA
87 Silver Coupe Way over 200k miles
Your car is fairly low miles. You might check your chevy dealer and see if it has a service replacement key switch assy. VATS has had a lot of problems with the contacts in the switch, so much so they revised the key switch and pretty well fixed the problem. If it has the orginal key switch it's only a matter of time.
My car still has one of the orginal 87 keys and it works fine. If you have the car worked on it will change the key shape but not the value of the key resistor. I know this because I had an orginal key re-cut and it is still my back-up key. There was meat where it could be cut down and work in the lock. Oh, the resistor pellets are known to fall out of the older style keys. You can get a key almost anywhere now, don't think you have to go to GM to get it.
That's the drill if the problem is VATS!
JS
Radar
Oconomowoc, WI
1989 Medium Blue Metalic Convertible
I think the VATS receives signals from the door mechanisim and key lock mechanisim so it knows if someone tries to tamper with the car (like using a locksmith cheater bar). When you had the door apart, it is possible that you disturbed some of the wiring harness and connections to these devices. I would check this out. The GM shop manual has wiring diagrams of the system and the inputs. I have an 89 so the wiring is slightly different but the theory may fit.
Welcome to the site!
Radar :)
Rabbit
sonoma ca usa
2004 C5 coupe, MSGM & 2014 Cad SRX Crystal red
As Radar suggests, check the door lock.
glen3107
Atascocita, Texas
1987 Black Coupe
Hi,
Thanks everyone for the good advice.
I took the cheapest route first and got a new key set. It seems to be starting OK, so I'm crossing my fingers and hoping that's the solution to my problem.
Just in case, I will get the wiring diagram to the door and check that out as well. I do think that I might have bumped or jarred something when I took the door interior off.
By the way, I was wondering, is it worthwhile to install the VATS bypass module that is advertised by MidAmerica and Corvette Central?
John
D
Drewser
VATS facts
As a locksmith I deal with these things all the time. Contrary to popular myth there are no VATS sensors in the doors . There are wires that interact with the alarm, but that isn't the VATS (Vehicle Anti-Theft System). The VATS consists of the pellet in the key (one of 15 different resistences), the VATS ignition which has two contacts just inside the "ears" that read the pellet and two thin wires which connect the lock to the module (located where Vigman said it was--under/behind the dash). The module is what actually reads the resistance value and either enables or disables your fuel pump, injectors, ect. (on some vehicles there is a starter interrupt). It is easy (with the proper diagnosis tools) to find out if your VATS is working. Call around to a few good locksmiths in your area. It shouldn't cost more than a few dollars if they are properly equipped. If you lived closer I would have you come by my shop and I would do it for free.
A few more VATS facts:
The system first appeared on Vettes in 1986, and on some early Caddys in 1983.
The #1 value is almost never used since the value is so low that plain keyblanks would sometimes work.
The timeout on the system is 3 minutes if the wrong value is attempted.
The single sided VATS keys were used exclusively until 1997 when the double sided VATS debuted.
The VATS system is slowly being replaced by transponder keys (a small inductor is now in the keyhead on some GM cars)
Resistors are the most stable electronic component currently in use today.
(and an interesting key fact, for me anyway: GM used the same set of codes for 99% of its cars from 1936 to the present. Only in the last 5 years have they started using a different set of codes for the new double sided keys. They used the same codes, but every year they would change the keyblanks--5 different sets--then they would start all over again)
If you have any VATS question, or key questions don't be afraid to ask. If I don't know the answer I can sure find it.
--Drew:w
glen3107
Atascocita, Texas
1987 Black Coupe
Thanks, you've really helped me a lot. Do you have any experience with the VATS bypass module?
D
Drewser
One more thing
On my 84 there is also a starter interupt hooked up to the door locks that is part of the alarm system.
I haven't had any direct experience with the bypass kit, but I don't see why it wouldn't work. You are basically inserting the appropriate resistor in place of the keyblank, and using a "normal" keyblank to start the car. You would compromise your security, but you could do it. If someone decides to bust your ignition and steal your car, it's theirs. If you keep the vats in place they will do damage, but they won't get the car.
--Drew:w
vigman
Motor head!!!!
Valencia, CA,USA
All the Bypass does
Is replace the resistor on the key... I wouldn't replace it UNLESS the key fingers OR the Key switch fails.
AND The door has NOTHING to do with the VATS!
Vig!
D
Drewser
Thanks Mike
I don't know how much those bypass kits are but VATS ignitions don't cost that much. If the contacts or lock fail I would just replace it. Let me know if you need a VATS lock & key and I will get it for you at cost, plus shipping.
--Drew:w
topless82vette
southern california
1982 convertible (not factory) stock 350cfi auto
I did a vats tubler change not on a vette but on my old 89 camaro the tumbler and new key was around 75 bucks through chevrolet all you need to do is take your old key in and gm will read the chip for free from what I remember the vats tumbler is as easy to replace as a regular one except on vats you have to drag the tumbler wires down through the column I used a clothes hanger on mine
glen3107
Atascocita, Texas
1987 Black Coupe
Thanks for the tip. Since I got the new key set, its been starting OK. Wish me luck, I'm hoping that was the solution to my problem.
glen3107
Atascocita, Texas
1987 Black Coupe
Well, the new key set worked for about a month. Today, the VATS kept the car from starting, with the new keys, about every other time (out of 6 tries it started right away twice).
Luckly I had you'alls' advice and that of past posts that I found on the VATS problems.
Today, I waited for 4-6 minutes for the VATS to reset and tried to start the car again. Amazingly it started right up everytime that I waited.
Guess I'm officially a member of the "Wait for the VATS" club.
Hey, without your advice, I'm sure I would have called a wrecker.
I'm sure glad that I found CAC.
Thanks Guys,
John
:cool
