One OLD Vats post
Running down the shaft are the infamous VATS key sence wires...in my experience when the wheel comes apart that get pulled & tugged... and IF it was starting to wear out this dosent help the process.
A quick way to check is the following get out your handy dandy OHM meter and measure the pellet on the key, write down the number ( eg 11.8k ) this is the value of the resistor to enable the VATS.
Now tear out the hush panel under the drivers side, and find a small 2 pin connector ( with 2 white wires and orange sleeving) These are the wires from the key switch that contact the pellet. Disconnect the connector and measure the resistance with the key out ( should be OPEN ) and then put the key in
and you SHOULD get the exact same reading as when you measured from the key directly. Jiggle the key around and see if is intermittant.
If it is, there are 2 ways to approach the problem.
1) Go to Radio Shack and get a resistor close to the same value ( +/- 10 %) or do the math and get a few to put in series to get the number closer to the resistive value on the key. Clip lead the new resistor value on the other side ( MALE ) portion of the connector to see if it starts. If that works
solder it in nicely to that connector, and DO NOT plug the steering coluum connector back in! This defeats the VATS system so option #2
2) Have the key switch assy replaced ( Expensive )
You'll have VATS restored but... any theif who wants your car knows about the VATS anyway so it does provide a slim margin of anti theft. I myself
have put a secret switch over by the vats and is shorts the key sence line out, & breaks the fuel pump line.
MY .02 cents
