steering box adjustments
yakatak76
seattle
1976 Yellow Coupe
Has anyone out there adjusted the steering box on their car? I have read up on how to do it but would like to hear about some actual experience to see if there are any tricks to it. Thanks
Also, I'm new to the site as I just purchased a '76 Stingray.
That link above is very good- I wish I had it when I did mine. I had some "slop" in the steering. I eliminated the tie rod ends, ball joints, etc. and found it in the box. The top adjustment was what took care of mine. Follow the directions and you will be fine.
thank you all, i was told by a buddy to check for slop before going after the box. the car has 168000 miles on it and i don't think the rod ends have been touched so i'm sure there probably is some slop. but with this info and some of the other stuff i have read, i may be able to just drive the car rather than herd it down the highway. thanks again.
I was involved with a post a month or two about the same problem. There is a way to check the front suspension components by jacking one side of the car up and "yanking" on the jacked wheel. Look for movement in the tie rod ends, pitman and idler arms. Movement= replace.
Most times the culprit will be the idler arm. It's usually the first thing to go. Buy a good Moog or other unit with a lifetime guarantee. After I changed mine, did the bushings and tightened up the top adjustment, the car drives great. No power, so I can FEEL what is going on.
Be sure to check the old (?) rubber bushings on the a-frames. With that mileage, I would think they are whipped. Mine were. For some odd reason, the rear bushings were all new. Don't know why the fronts weren't done.
Ball joints usually don't affect steering, unless they are really worn. Again, that is an easy check for a trusted alignment shop.
The steering boxes aree usually prone to wear, but from what I read in the post previously, you can easily find the problem. I'm going out to the barn after it gets above -6 degrees for a while, and check mine for the shaft movement.
My mechanic friend showed me how to adjust the steering box on my '69. What an improvement! Don't over do it though!
ok, i give up. what did he show you? did he do both top and bottom per the chevrolet manual, or just the top? did he dis-connect the pitman arm? did he do it via feel as described in the url that was listed earlier in the forum topic? is it something you would feel comfortable doing on your own now that you have seen it done?
