Johan
I'm removing my steering box from the car to rebuild it. I have removed the bolts, but how do I separate it at the flex coupling?
I have opened both clamps, but It doesn't seem to be enough room to separate the steering box from the steering column, do I need to loosen and pull back the steering column??
Also, when I put it back in, how do I ensure that the steering wheel ends up in the right position? It doesn't seem too easy to adjust the splines at the flex coupling, is it possible to do this at the pitman arm? Or should I just get it as good as I can, and then adjust it at the tie rod ends?
