Steering rack leak, where to get new
I
Igor
Hey guys,
I have a leak out of my steering rack out of one of the transfer tubes.
I just did bushings in the entire car and had the rack out to change bushings/fix leaks on rack. Got all leaks on rack fixed but the one transfer tube. Its leaking enough to paint my new engine and piss me off.
I took the transfer tubes off when on the bench and nothing looked cracked/broken. There is no seal there, just compression flared fitting. I re-installed them with red loctite and torqued them to speck, and now still leaking out of that one transfer tube. I did use 1 bottle of lucas stop leak and no change.
So I think I am forced to look for a new z51 rack. My car is 85 z51. Any idea who sells a re-maned or new rack and how much?
Thanks.
Lucas wont help a cracked tube,damaged flare,damaged nut,or damaged seat,just a seal or O-ring!!:thumb Do some close inspection under a magnifying glass,you missed something!!(Chunk of Deb're,Cracked Flare,Cracked Seat or Nut!!) ;shrug;shrug;shrug
