Hello Guys and Gals, haven't posted here in a while, as everything has been going along pretty smoothly! Recently though, the steering has been getting a little loose, so I did some checking today. There's an intermediate shaft that runs from the firewall to the steering gear, and I found that the U-joint nearest the R&P has quite a bit of play in it. Looks like I'm going to have to replace it. My FSM makes reference to removing and replacing the entire shaft, not just the u-joint. :eyerole
I used the search to try to find some info on the problem, and found a couple posts from a couple of years ago that said the part was no longer available!
hnoes Has anyone had to replace this piece, and if so, were you able to find it new, or did you have to find one at one of the Corvette salvage yards?
Any information would be greatly appreciated!
Barry
Barry
