johnrem46
I had asked this question once before.. I am tring to replace an aftermarket steering wheel on a 74 with tele column. I was told that you just need a screw driver. Well I removed the horn button,horn contact and shim,lock start screw,lock ring and spacer and the nut and washer. The wheel will not come off?? Do I need a wheel puller? THE AFTER MARKET WHEEL LOOKS SO DIFFERENT THAN THE ORIGINAL?? Has anyone replaced the steering wheel on a 74 that can shed some light on this. Is the original steering wheel the same for a tele column and standard column?
