7
76L82
I finally broke down and replaced half of everything up front on my 76L82...the power steering cylinder, power steering control valve and the ball joints.
Before I replaced the steering cylinder and the control valve, I made sure that the steering wheel was in the neutral positoin...perfectly horizontal. I replaced the control valve and didn;t even check inside the car to look at the steering wheel to see if it moved. I then finished off putting the new steering cylinder on and followed the manufacturers direction and adjusted the unit..making sure it was perfectly centered. Everything looked great and fit...what I thought at the time...perfectly.
I lowered the Vette off the jacks and started it up again to give it a test drive...rot roo raggy! The steering wheel now is about 1/8 pointed to the right while the wheels are completely pointed straight. The thing drives perfectly straight down the road, no pulling of the wheel...but the steering wheel is now cocked to the right.
I think I may need to take the control valve off the pitman arm and unscrew the control valve from the stabilizer bar...essentially making it move closer to the left wheel.. This should basically push the ball joint on the control valve a 1/4 inch or so to the left...moving the steering wheel with it.
Does this sound like the right fix???
