(snip)
I don't want to hijack this thread...
Yeah...but you did, anyway.
But widening the focus of the discussion is a good thing.
My earlier post did not state or imply that the old 461 "FI" head would not support 400 at the flywheel. In fact, back in the day, when I was a bratty kid building SCCA B/P engines, we had 327s that did that--actually with open exhaust, on racing gas, with an aggressive spark curve and Rochester FI, we were probably about 410.
If there was any implication in my earlier post, it was that modern aluminum heads, when properly matched to the rest of the engine, will make that 400-hp at the flywheel with a flatter torque curve because you wouldn't need as much camshaft.
I looked at those dyno numbers and, indeed they're SAE-corrected, a standard which offers a more real-world comparison, but I have a question on the results: the pass where you saw 353 was in third gear. The dyno operator made one pass in fourth gear but the power was way down and the power plot, even with smoothing set to "5," was quite jagged, as if the engine was in detonation. What happened on that run?
I, also, noted you could only achieve 353 at the wheels with open exhaust. I suspect that "open exhaust" means you had headers on the engine. While you haven't stated your full package of modifications, would it be fair to say your 327 has more aftermarket enhancements than just headers and ported heads?
The fact remains that 355-rwhp at 6300 rpm (about 430 at the flywheel) is impressive from your 327 using 461 castings.
Another issue is that the OP listed 400-hp
at the rear wheels as the goal. That's around 490 at the flywheel and my opinion remains that figure would be difficult and costly to attain with any Gen 1 SBC of 327 cuin., regardless of cylinder head choice.
