I was on my way to visit my friends at the paint shop this afternoon. I pulled into a Tim Horton's drive thru (as usual
) and shut the engine down so the person on the other end of the squawkbox could hear my order. Then, I pulled to the pickup window and shut 'er down again. I also flipped the electric fans off........too noisy.
When I pulled away, I flipped the fan switch back on, but noticed the temp rising after a few blocks.
"Hmmmmm", says me. :confused
I pulled into a lot and checked. Sure enough the dual Spal fans weren't running.
I was able to scoot home before it got too warm. Once I got into the garage, I checked all the power and ground wires, and the fuses. Everything checked out okay, except that jumping the sending unit to ground would not make the fans come on, as it should.
As I'm scratching my head, the fans suddenly turned on. :eek
Ideas?
P.S. Now that it's cooled down, I jumped the sending unit to ground again, and the fans came on (as they should).
Ideas?
