D
dalton0814
My 95 has an odd noise - seems to be coming from the rear, and is only noticeable when I turn it off. Turn the key, engine cuts, then sounds like a motor or whirring noise that cuts a second or two later. It's not the antennae, everything else seems to be running fine (except the low-temperature knock I get when first starting until it gets to about 180, but that goes away pretty quickly). Not sure what this noise is and I've searched everywhere. Is this like the ABS noise noted in other posts or could it be something else? Thanks for the help!
You'll find lots of info here and very nice folks.
