Question: Strange Transmission noise
Hey Karl-
Glad to hear you FINALLY got GM to buy the other car back.
Thanks Hib. It was a long and SLOW process. Glad to back in a manual.
Shuddering
Is this anything like the infamous SHUDDERING THAT HAPPENS BETWEEN 55-80 MPH. MINE STARTED 6600 MILES AND I HAVE READ SEVERAL WITH THE SAME PROBLEM 2015 Z51
corvette addict
Shiddering
No I never had that problem. The torque tube bearing kept failing. First at 6 months then 2 months later then a month later and then a week after the repair. I would hear it when coming to a stop and occasionally when on the freeway and letting off the go fast pedal. Never a shudder. They said the check the crankshaft for end play but they never said if they checked the transaxle which I felt was a more likely culprit.
