V
vince v
I bought my first vette around nine months ago, an 86. I love this car. I brought it in for state inspection and it failed. Found out the air pump was disconnected and had no cats. The engine has a high performance cam (don't know much about this) and performance chip. The idle was rough and high (1100 - 1200 rpm), the mechanic said I needed new fuel injectors. Also replaced EGR switch and valve. He replaced the chip with a stock chip from his 89.
I got a temp inspection, good untill Nov. The idle dropped to 800 - 900 with better mpg and higher performance. I changed the coolant and t-stat (160 deg), performance improved a little.
A few months later the high idle is back 1200 - 1300.
Does anyone know the cost of new cats and what is involved in installing them. Also, will this help the idle.
