like2drive
stripped bolt attaching brake caliper.
As I was torqueing the new brake caliper today to my recently rebuilt trailing Arm assembly...(.I believe its actually on a spacer on the strut support.)..either I cross=threaded one of the bolts, or it was already messed up. Question: do I use a Heli-coil , or thread and tap one size larger. The bolt is actually a 7/16-20 thread which is a fine thread. I m thinking due to the heat, It may be better to go to a 1/2 inch instead of the Heli coil. Appreciate response.
Incidentially, this whole project has been a mess like this!
