- Joined
- Mar 26, 2002
- Messages
- 813
- Location
- Deep River, CT
- Corvette
- 1981 white/blue interior automatic, 1999 torch red/tan interoir 6-speed coupe
I had to replace my right-rear caliper last week, but when I went to tighten the right mounting bracket bolt (towards the front of the car) it didn't feel "right." I decided to check on it again and now I can feel that the bolt hole appears to be stripped. I went as far as replacing the bolt, but as soon as it grabs the threads and you start to torque it, it "slips" back and turns freely. I've done a TON of reading on this, and I can see other C3 owners have had the problem. My question is:
1. Do you think I could get away with just using a 7/16"-20 thread chaser, such as this one? Is it even worth trying?
2. Or is the Heli-Coil the way to go? I've never used one... do I have to take the entire trailing arm off, or do you think I could drill and tap the hole while it's still installed? That solid brake line looks like it's going to get in the way.
Thanks for the help!
-Tatortot
-Tatortot
