madvette74
these parts(except gear drives) have a hair over 1800 miles.. these are .40 overbore stroker Silvolite hypertectic pistons part #H3426-040, the rings are sealed power piston rings Part# E-251x40 and gm rods(receipt says som stage one rods) theses are 5.75 rods that came out of my stroker motor, I have also a compextreme cam with a 487/490 lift 230/236 duration with the lifters numbered so they go on the same cam lobe. camshaft part number is 249-CL12-246-3 at jegs.com the push rods are crane hardened, I paid 80.00 for them.. you make look up the part number at summitracing.com the pushrod part number is cca-7372-16 I have all the receipts also a gear drive setup, the name brand is Dynadrive. I have the installation manual, I just cant find the additional bushings to advance your timing, I have the one that that is zero degree.. this part has approx 4000-5000 miles on it.. I have the camcard for the camshaft it's hydraulic tappet..
I can take addition pictures, I had AFR heads with 68cc chambers, and with this setup it was to be 10.51 cpmpression.. the motor was a stump puller!! with this setup..
no reasonable offer refused.. I can supply more pics if you like..
