8
86Gold
My 86 has developed an annoying problem I can't seem to run down. When I'm cruising down the road (constant speed) and the driver's window is down I smell gas - very strong. At idle there is no smell. With the window up there is no smell.
I've replaced all the rubber lines on the gas tank vapor recovery system. I've replaced the vapor canistor.
Fuel pressure is normal and a bleed down check indicates no leaking injectors.
Fuel injectors only have 20k miles on them. Just replaced fuel pump and filter. New gas cap.
Sitting in the driveway,idling, I can't find any sources of a raw gas smell.
Any ideas?
Any ideas?
