stuck hood 1978 pace car
  • Thread starter Thread starter mbpsycho
This comes up so often. Everyone should take a look at how the latch system works. First, run the wipers fully up and park them there(turn off the ignition when fully up). Look to the inside of the passenger wiper down at the base. You will see a small plug. Take a long screwdriver and push in on the plug until it pushes in. Then take the screwdriver and insert it in the hole near the bottom. You need to push straight in, do not pry or twist. What you are doing is pushing down on the lever that the cable normally pulls down on. Good luck.
Mike
