Jeff Farrar
Don't try turning the rear wheels if they are off the ground and hanging. The half shafts will be at an extreme angle.
Jeff Farrar said:Don't try turning the rear wheels if they are off the ground and hanging. The half shafts will be at an extreme angle.
rohard said:Would that cause the difficulty I am having turning the wheels? Seems like that would bea constant drag if the U joints were binding. What I have is a relative
ly easy turn then they "freeze".
I have always considered the rear brake lines as 'sacrificial'. Have a pair on hand when R & R the calipers for kits or bearing maintainence.Worried about breaking or bending the brake line
Kid_Again said:At least you know for sure.![]()
