-the case of the floppy header visor...
Phil, -it just proves again that all great minds think alike, in as much as I recently fixed my driver's-side visor so that it no longer tends to droop say 5-degrees down from its original proper position up flat "saluting smartly" proximally against the ceiling of the car's roof. No big deal, but like you, -its just one of those pesky if trivial little things that you'd like fixed (preferably for FREE!). ---Well sir, my '80-C3 has the same white/nylon-bushing like end-piece which is apparently just slightly worn enough to let the visor droop. Fixed it just fine by cutting some thin-aluminum (a disgarded frozen-pie dish was the donor) with a regular sissor into an approx. 3/4"-square piece, -then starting from one-end folded it over flatly upon itself into an approx. 1/8"-wide x 3/4"-long strip as a shim to be inserted into a narrow slot you will see formed into the support-arm (if it turns out to thick, -just unfold your shim and cut-away a little and retry, -until it all fits snuggly when re-assembled). Anyway, you will get the idea better when you take-apart the white/nylon-bushing, and see that by inserting this shim you can entirely eliminate the droop causing slop condition, yet it still slides and pivots as intended.... Wheeeehhu!!! ~Bob vH
:TALK :dance
