Hi All:
I just bought a 1989 convertible 6 speed off of Ebay that has a 1995 ZZ3 crate motor in it . When I got the car, I found that the motor had the following added to it: Lingenfelter Superram upper and lower intakes; fuel injectors and rails; 58 mm throttle body, and ceramic coated headers. I got the receipt from the seller, and the work was done in 1995 when the engine was installed, at Lingenfelter in Indiana. I know the ZZ3 supposedly has 345 hp from the factory. Any idea what kind of hp was added with the Lingenfelter items? The engine feels as though it has a mild cam in it, but could just be the way a ZZ3 runs from the factory.
My nephew races WRX's and after driving the car says I only have about 300 hp at the rear wheels.
Also, the A/C doesn't work. I had a shop look at it and they said the following: The compressor is fine, they charged the system OK, but the "Blend Doors" don't operate and that's as far as they will go. The car does have the climate control system in it. Any ideas if I can fix it? Is it a common problem?
Thanks for any help. I am a Mustang 5.0 guy converting to GM.
