J
jon79flavette
Does anyone have the routing diagram for a 79 vette, on the hoses for the headlamps. They worked fine before the motor was in, with the exception that the pass side was about one half second behind the drivers, I can live with that. Do the hoses to the cruise control have anything once so ever to do with headlamp operation. is there a check valve of some type? With my motor, I am pulling vac of, about 14 inches at idle, and about 22 inches a 2500, Is this adequete. Also when I pull the hose off the headlamp switch, I always got the loud hissing (pulling vac) now nothing. I have very little knoledge on these lamps/hoses, any help apprceiated, Jon
