C
Chuck-75
Im about to install a new street-N-slamon HD suspension. Ive seen previous posts that have shown pics of the mounting plates ,where the lower A-Arms mount to the frame Cross member that have seperated. Is this a weekness? should I consider adding some more welds to this plate before I start to install the new suspension? (has anyone done this before?) also will this weeken the frame if I do?, and what about the plate thats welded to the lower A-Arm for the sway bar mount? is this strong enough?............. I have a base factory suspension originaly.No rust and the frame looks solid. Im installing new 550Lbs Ft. springs, and 1 1/4in sway bar. In a 75 vert... thanks all
save the wave
save the wave
