Whiteshadow89158
So i was browsing through the shops and i saw a rear sway bar. Does the 81 come with a swar bar? Mine doesnt have one and if so can i get a pic where it mounts?
Do a search on rear sway bar. I went through this already. If you need pics, PM me with your email and I'll send them. Normally, if you install a rear sway bar, you will have to upgrade your front sway bar to prevent over/understeer.So i was browsing through the shops and i saw a rear sway bar. Does the 81 come with a swar bar? Mine doesnt have one and if so can i get a pic where it mounts?
...Does the 81 come with a swar bar?...
This is what I ended up doing. It did change the feel and the ride. I think I have the rear end links to tight.I found that the 1.125" front bar and 9/16" rear bar gave me fairly neutral handling. A big block would require a bigger rear bar.
No, the rear sway bar is custom. I'm going to experiment with it some this weekend. It takes a little more adjustments to keep the car center when steering. She seems to handle nice around turns though.Since the rubber isolators in the links have a steel bushing, I don't think you can get too tite. Is it the stock factory setup?
Actually, I did do my research. My rear custom sway bar fits. I have an original rear sway bar as well. The directions that came with the rear sway bar said that I should be able to turn the spacers by hand on the end links which to me were to lose so I tightened them. The car feels different so I need to loosen them. No problem here just experimenting with ride and fitment...IF yours did not come with factory sway bar then do your reserch not all rear setups will work. A factory setup should, afterrmarket may not. Mine did not have the sway bar, the holes are in the frame for the mounts and on the trailing arm.
I purchased an entire VBP suspension system. Everthing bolted up fine except the rear bar which still is not on, as it will not fit properly. VBP make great parts and they have worked with me on this, however still will not work.
tcxd40
