steelelazer
New member
I recently bought a 93 C4. The dealer had promised to change the battery...he didn't. After having it in the shop getting the ECM fixed and the digital cluster repaired(a loose connection causing the cluster to go out), I started seeing "SYS" flicker on the cluster. The car was running fine, but now when I turn it off it won't fire up without a jump. If cables are hooked up , the car fires right up. I have seen anything from "It's a bad battery" to the alternator to ccm. I have replaced the battery and just wanted to try and figure it out before I go replacing the alternator or taking it back to the shop.
