74bigblock
We started the major portion of the tear down due to failed left rear spindle bearings. Basically, all we have left is to get the T-arms out. Thank goodness for air tools. Some interesting things we found:
-Birds nest in the Diff cross member.
-I had one bolt, and the biscut mount holding up the diff. The other 3 diff bolts were cracked off a long time ago, and the bolts worn down. One of the bolts has ceased itself into the crossmember hole, the other 3 are ovaled out.
-Left inner spindle bearing... total carnage.
Check it out:
Check it out:
