MatthewMI
Just picked up a basket case 1988 C4 with the fuel pressure regulator pulled out. Of course there are no T10's to put it back in.
Any suggestions on replacements?
Thanks!
Thanks!
The T10 tamper-proof screws are about 3/8" long. You can probably get them at Home Depot or the like. Also Google T10 screws. They don't have to be tamper proof. There's a lot of them on E-Bay too.
If the regulator is suspect(to be bad) check out Corvette Central (.com) and replace the whole assembly with an adjustable regulator. Part # 304570 Here's a link.
http://www.parts123.com/corvettecentral/dyndetail.pta?catalog=0000050W&ukey=30471
Tip: When assembling the fuel regulator, do NOT pull the cover down tight to the base with the screws. You will rip the regulator membrane. Clamp the regulator together, then install the screws.
Good Luck.
