eoseitz
I finally installed my new hei tach drive distributor. Considering the last guy that owned the car had removed the timing chain cover and put one on without marks, I managed to install it pretty easily and it runs far better than it used to. However, when I went to hook up the tach drive cable, it didn't want to go on. After looking down in the part that screws on I noticed that there was no gear in it. Does this use vacuum or is it gear driven? It appears to be a vaccum hose unless something is broken. It comes out of the firewall where the wiring harness does and it has a screw on type thing. Any info? I can post pics for confirmation or if you have some could somebody post one?
