Heyblue
Had to replace the key cylinder so took things apart, I thought I paid attention to the order of things, but not convinced. Also not sure if previous owner took it apart and weather he put it back together right. A clue is the steering wheel was on upside down.
I have the shop manual also. The first thing I had to do is buy a set screw to replace the star one that locks the telescoping shaft, otherwise the tool didn't have long enough legs to press the lock plate down.
My issue; it seems that the horn will never work when the steering wheel is telescoped out, in fact because of the spacers it may never make contact.
The order from the outside going in on my car is Horn button, 2 screws holding the telescope lever, the lever, the nut holding the steering wheel, the steering wheel, a clip ring, two Teflon washers sandwiching a spacer. the c ring holding the plate, the plate, a plastic assembly with medal plate on bottom (towards front of car) with tabs passing through the pressure plate.
According the the shop manual there may be another assembly in the mix that is missing above the pressure plate.
Any clues?
Any clues?
