Temp light dim
dwm
wv
1988 Coupe
The temperature gauge on my 88 is dimmer than the other gauges(oil pressure). What do I need to check? I know that you can turn them off but I never do.
Same Issue
dwm,
I just posted a thread with the same issue and saw you did same more than a year ago. Didn't see any replies. Did you get the problem fixed and if so, what needed to be done?
You probably have a bulb burnt out:)
