Hi all,
While going over all of the wiring on my car, I discovered that the kickdown switch that is attached to the gas pedal is disconnected (only on turbo 400 transmissions). I tested the switch to see if it works, and it does. However, I do not seem to be getting any current from the harness that plugs into the switch, and the wire is quite difficult to trace. Any ideas to help diagnose this problem?
Thanks in advance,
Vince
Thanks in advance,
Vince
