Have you considered another OD?
I desperately need an OD now that I had the 3.70 put in on the 12 bolt.
Since the whole reason I got into this red sinkhole for money was to have a home for a monster BB I have to build before I expire, I was concerned about a tranny that could handle the torque.
The poster was right - the 4L60 (700R) is a "4" Speed "600" ft-lbs of torque rated thingy - from the factory. This was VERY optimistic in the earlier models from everyone I can find out anything from. Early or junkyard 700R's are frail indeed.
The 4L80 is MORE than just an OD on a Turbo 400. It is rated at 800, and this rating was probably understated, but it is ENORMOUS and HEAVY - about 125 pounds heavier than the 350 and dimensionally larger even in the aft-of-bellhousing area. (It had been my choice on paper, until I found out all this badness.)
The good news is a number of companies have greatly improved the 700R/4L60 over the later factory redesign even, bringing it up to a useful 800 ft lbs use, and not intermittently either, although most of those go for $1200-1900, just for the tranny.
The route I am planning on going though offers even more power handling and all the electronics are self-contained (a problem with the massive 4L80.) I am - and would already of done it, if a minor rear axle didn't decide it's number was up - putting in a Gear Vendors OD unit.
Installation of this thing does not sound as simple as a tranny swap, but they were downright insulting at GV when I told them I had a tranny guy who was going to do the install for me for $750.
They claim it's easily done by any moron.
They describe it as a "coffee can" sized thingy that bolts on in place of the tailstock on your T400. Aside from dropping the tranny - or even just tilting it, you have to notch two squares in the glass at the rear of the tunnel and have the driveshaft length changed at a driveshaft shop - and run a place for a switch. (You will normally need to do that in any tranny switch anyhow.)
I hope to see as soon as the OverDrive Fairy leaves me the buckaroos under my VettePillow.
Besides being rated at 1250+ ft-lbs in the regular form (more than a stock T400,) they offer not just an overdrive, but a true 6 speed automatic function. The unit functions as a gear splitter as well as bolting on a 70% drive on top. So you get the close ratio shifting of a 6-speed like out of a nicely equipped C5, although your top ratio is .7, not .5 - but no clutch to burn out in six weeks of careful abuse!
The price of these puppies is about $2300 raw - my tranny guy would charge another $800 or so, so I'll just get my fat gut crushed under the car sometime this spring, hopefully.
Just more choices!!!
