The 68 heated up to 240* at stop light.. Help
jims427400
Temperance Michigan
67 427 tripower,68 427 tripower,04 Z16, 62 340hp
Drove the 68 home for the first time tonight. It was a little shaky, vibrations through 1st and 2nd gears. 3rd gear pops out during down shifting but my initial concern is that at a long red light the temp guage climbed quickly to 240*. Its got a new water pump and thermostat 180*. One thought I have is the fan clutch spins freely w/ very little resistance. Can this cause the car to heat up quickly. If not , any other thoughts.. Oh yea, it was like 85* outside
jims427400
Temperance Michigan
One last comment, as soon as I got rolling again, the temp came down..
fine69
Maryland / D.C.
'69 Convertible Vette; '72 Z28 Camaro Rally Sport
Yes, the fan clutch can be a contributor to the heat problem.
When you stop your engine the fan should continue a few times. If it continues to spin, you should replace the fan clutch.
Good luck to you. I know a hot car can be misery.
petes74ttop
Mount Holly N.C.
1974 T-Top
When you shut off the motor the fan should stop in 1 or 2 seconds, if it spins longer than that it's time to get a new fan clutch. PG
jims427400
Temperance Michigan
Thanks 69,
I may be spoiled but I cant imagin how these original owners drove these cars on hot summer days. I was roasting and that was even w/ the top down.
A new fan clutch is in my future.
68Roadster
Dallas, TX
'68 White Vert '05 Silverado SS
Jim,
Hope the clutch fixes the temp problem....
I can sympathize with ya on the top down roasting problem....by the time I get home my back is wet with sweat.....need to replace my top and get the A/C working again......always something!
bossvette
Gone but not forgotten
West Unity Ohio
do you have a shroud around the fan?
Wayne robson
australia
sold my last corvette.
cooling
Hello.the best test for fan clutch on a corvette is at cold motor condition, approx 70 degrees,pull your fan as hard and fast as you can by hand, and it should not spin more than half to three quarters of a turn, on other gm cars Buick Caddy Olds, etc, its still ok with approx one to, one and a half spins, also there should not be any significant play in the side or bearing movement.
1 other reasons,low coolant.
2 faulty radiator pressure cap
3 thermosstate stuck shut
4 slipping belt
5 timing
6 corroded system.
regards wayne.
SIXFOOTER
Boca Raton Fl
1981 L81 Tan Coupe
a Note on the fan clutch, it shoule make less that 1 turn when you shut the motor off while it is warm
It sounds to me like you had air in the system, like mentioned above it will act like low coolant, once the thermostat opened up it may have equalized. Fill it with 50/50 and take a ride see what happens, take the 50/50 with you
The way to avoid trapped air is to drill a couple of 1/8" holes in the thermostat before installing it. That allows the air to bleed off filling the water jacket with coolant
chevy6673
illinois,crete
1973 Corvette ,1966 ss impala
ok lets recap i have a 73 L 82 in my 66 the fan cluch not sure what it came from swap meet part, i turn off the motor it stops not even 1 turn,, but then i can turn by hand freely is it good or bad ;shrug
jims427400
Temperance Michigan
I have the same result.. turn motor off and maybe 1 rotation. Turn motor off and spin by hand-very little resistance, but my machanic says its bad. hmmm
chevy6673
illinois,crete
WELL MAYBE MINE IS ALSO BAD LET ME NO WHAT YOU END UP DOING AND IF YOU GET A NEW ONE HOW DOES IT ACT WHEN MOTOR IS OFF;shrug;shrug
petes74ttop
Mount Holly N.C.
1974 T-Top
I just tried mine, the cars been parked for 6 hours, I cannot get 1/2 turn by hand, so I agree it's BAD. Try http://www.lbfun.com/corvette/tech/vettetech.html lots of info there. Scroll down to cooling.pdf by John Hinckley. Hope this helps, PG
minifridge1138
USA
1982 Black Fastback
I have had a LOT of experience with my corvette overheating.
Here is what I did, and the order I did it in:
1) check fluid. Check the reservoir and check in the radiator itself. Make sure there IS fluid in it.
2) make sure the fan spins correctly. You've already got plenty of info on that.
3) Check the thermostat. Many thermostats stay closed when they fail and fluid can not flow. Replace with a 180 degree Mr. Gasket (when they fail, they stay open).
4) Check radiator. If it was leaking and someone put a can of stop leak in it, then odds are good that it is clogged. Buy a new radiator or have the brass/copper one re-cored. Personally, i bought a Direct Fit Aluminum radiator from DeWitt's. Nobody makes a better radiator.
5) Test water pump. I don't know the best way to do that (my problem was the radiator).
(can you tell that overheating is a common problem in C3's ?)
6880 Mike
The Bluegrass State
1968 convertible; 1980 L-82
Add these to the list:
Correct radiator in good condition.
All required radiator support seals.
Correct fan shroud.
All required fan shroud seals.
Koop
Kalifornia
YELLOW 69 modified GM Crate ZZ383, LS2 TBSS
Why don't ya'll just pull out that thermostat?
Bubba. :gap
mason1968
Santa Cruz, CA.
1968 corvette roadster
I have a 1968 with a GM350 create motor with a B&M 144 supercharger. I had the same overheating problem as jims427400 reported.
My solution required me to replace the water pump, radiator and the pulleys, listed below is what I did.
New water pump from Stewart stage 3 water pump and the recommended thermostat rated at 165 degrees. http://www.stewartcomponents.com/
Radiator from dewitt, this is a direct fit aluminum radiator. http://www.dewitts.com/
New overdrive pulleys from March Performance. http://www.marchperf.com/ The overdrive pulley will spin the water pump faster. This is a requirement for the Stewart Stage 3 water pump the increase speed increase the water pump pressure at idle.
I also use a flex-a-lite 7 blade unequally spaced blades. This increased the air flow thru the radiator at idle.
After all of the changes the engine never, and I mean never, have the water temperature go past 180 degrees and most of the time it will stay at 165 degrees which is the rating of the thermostat.
mason1968
Santa Cruz, CA.
Oj I forgot to mention that you should replace all of the seals that are between the radiator and the radiator supports.
It is very important to have the area ahead of the radiator sealed completely to ensure that the are flowing into the front passes thru the radaitor.
