theft deterrent system
jimbil208
pa
1982 collectors edition
1982 collectors edition theft deterrent system shows a relay under the hood ,mine has none,can anyone tell me where it should be? Does anyone have a picture? also I have an under hood lamp with no switch. Anything on that? Does anyone know where a place is to get relays and switches for the alarm system?
Thanks, Jim
the only relay I'm aware of is the starter interrupt relay,which is in the console in the area to the right under the ashtray...the computer hook-up is under the ash tray...
if you look in the in section 8A(at least it is in my book,BUT I also have an '81 but the should be close)there is an index that shows you how the body and chassis electrical should work and where the components should be found.
hope this helps....
the plug and the control mod is in the passenger side comp on the front wall!!!
