joshwilson3
I must say that this is one of the most civilized forums I've been on. Many different opinions, and no flames. Also some interesting points of view. The question about hotter temperatures and head gaskets is a good one. The only time I've had head gasket problems was when my electric fan malfunctioned and let the temperature go way up. Could a cooler thermostat mitigate head gasket problems, or does the thermostat only affect the time to get to operating temperature? I'm starting to believe that once the car is at operating temperature the thermostat is open for business and has no more effect on the temperature.
Your thoughts?
I think my thermostat was stuck open when I first got it. Because the temp was around 160. Put in a new stat, and the temp went up. Right now I have a 195 Robertshaw thermostat. I checked in on the stove, and it starts opening at 180. Where as the 195 stant starts opening up at around 195.
Riding around town, my temp is around 175. If I idle for a while with the heat on, it stays under 200. If I idle for a while with the heat/ac off, then it goes on up to the 230 or so till the fans kick on.
But with me driving around town it is staying around 175-180. So, I guess I don't sit long enough at stop lights for the temp to go up. So, I'm sure if I had the 195 stant in, then my temps would be higher running around town.
