joshwilson3
ok i'll drain it...
how about from the throtle body hose?
..the end of it is well away from the opti spark and there is no crawling under....
will it work?
I'd drain it from the radiator. As that is the easiest way to drain the coolant. You don't have to crawl under there. There is a plug at the bottom that you unscrew. I stick my under under the fender wells to access that plug while I look down from the top.
You really don't want to take a chance and get coolant on the Opti. It would also be a good idea that after you dump the coolant in the radiator. That you place a wrag on top of the Opti just in case a little bit of coolant trickles out when you replace the Thermostat.
And those hoses don't just come off. You may have to cut the throttle body hose as I'm sure it is stuck. If you do drain it via the throttle body hose, you probably will get coolant on the Opti.
