G
		goertz
ok, I've only had the '69 for a week or two now, but a few things have come up that baffle me. Here's the history, #'s matching engine was rebuilt about 1000 miles ago, and stroked to 383. On the 4th of July, we went to watch some fireworks. when we were leaving we were stuck in traffic. at this time, i notice when the other car's headlights hit the car, I could see oil smoke coming from the left side pipe. You can't see it in the daylight, but when headlights hit it, it's REALLY NOTICEABLE, and just seems to do it at idle. If you crack the throttle and clear it out, it stops for a minute or two, then comes back after it idles for a little bit. I was thinking a bad valve seal. But when you start the car, there is NO noticeable smoke on start up, which is typical with bad valve seals. There was a bad lifter in the engine, so I needed to replace that and figured I'd do valve seals at the same time. I did a cooling system pressure test, and a compression test before anything was taken apart, just to be sure. Those tests turned out fine. cooling system holds 15 psi for a half hour or more, all cyls read 180-185 on the compression gage. When I pulled out the #6 plug, it was wet with oil. when you crank it over, you get some oil spraying out of the #6 plug hole. So I pull the intake to do the lifters, and inside the ports of the head and intake on #6 is a brown slime that goes all the way up into the intake manifold. It's obviously the oil that the engine is burning, but where could it be coming from? I wouldn't think valve seals would cause a mess like that to travel UP the intake. Intake gaskets looked ok, not coming in from underneith or anything that I can see. All other ports  look dry and fine. Only #6 looks like this. any thoughts?
