A
Alfonso Gomez
ad My 1987 Coupe started acting up this morning. Yesterday I took the radiator cover off to remove the debris that accumulates between the radiator and de A/C condenser (leaves, and other garbage). Did not touch anything electrical. I used the car yesterday and everything was fine. This morning it started OK, I drove it out of the garage shut the engine to close the gates and when I tried to start it again, it went CLICK. :confused No power anywhere. No lights, no horn, no radio, instrument cluster completely off. The car has a new battery, starter (1 year old), and new alternator. I removed the positive cable from the battery and put it back on. The power came on: lights, radio, instrument cluster. But when I tried to start it, everything went dead. I tried this about 5 times with the same results. I tried jump starting it but that did not work either. I called a friend who is an electromechanic and his opinion is that the problem is a loose or damaged ground but was unable to pinpoint where exactly. My car is sitting halfway out in the street which is a no-no:nonoAny of you guys have any ideas?
