Thread sealer
  • Thread starter Thread starter billv
B
billv
What is the best thread sealer to use on oil pressure sending units? I used Locktite hight temp, and think it's still leaking at the block. Maybe I didn't let it cure long enough. If there is anything better, I'll try it next. I'm just hoping it isn't the intake leaking!
I would try using teflon tape or pipe thread tape. You should be able to pick some up at your local hardware/plumbing supply store. Wrap the tape in the opposite direction that your threads are. The sending unit will turn in clockwise, so wrap the tape counterclockwise. That way the tape will stay on. The tape will fill in between the threads and seal them tight. I have used the stuff before for similar things and it has performed well for me. The tape is not sticky, it clings to itself. 2 times around the threads should be plenty. Good Luck!!
Yep, teflon tape works well on these.
I had thought about that, but didn't know if it would hold up to the high temp and pressure
Victory Red C6 is correct. Teflon tape works well. I also use it on the coolant drain and water pump pipe plugs. Your sending unit will seal just fine with it. 2 wraps is just right.
Rick
:gap
