vigman
Motor head!!!!
- Joined
- Feb 13, 2001
- Messages
- 3,471
- Location
- Valencia, CA,USA
- Corvette
- 88 Convert ( SOLD ) /1973 coupe 4 speed/1964 Vert!
1) How do you get the oil bypass slug & spring out of a stripped block?
2) On the side of the oil filter casting there is a freeze plug looking thing ( where the oil temp sender would go) how does one remove it and what is the correct thread pitch & size for that hole?
3) Assuming the following ( 327/350-370hp)
Assuming that GM rated the 2 bolt small journal forged crank to handle that kinda output.
Is it safe to assume that I would not need to "beef it up" any more than it is.
AND
Would ARP studs be a better setup than going with the stock bolts from a clamping standpoint?
Mike
AND
Mike
