A
AlcHEmiE
Well i bought the vette on saturday, and have since but on all new rotors/pads ($450) and new tires ($500). So finally i got a chance to drive it today.. For a little while. I took it out and its been idleing wierd. It idles around 700 rpm, and then drones down to 400, i see my check gauges light come on, and just as it's about to die, it kicks back up to 700 RPM. It does this maybe, once every 15 seconds. And it only does it at idle, not under load. Thinking it was a vacuum leak, i checked all the hoses. Nothing. Then finally after about 3 hours of driving i get my SES light. So i run over to AutoZone (Good friend is the manager) and he gets out the diag. key. Throws a code 32. EGR valve. So i open the hood and start to look for the EGR valve. I finally found it, and you all know where it is.. heh.. Now about getting the TPI system off.. How hard is it? I mean, im pretty sure this is the LAST of my problems (crosses fingers) Any advice? Should i just clean the old EGR valve or replace it ($45) and if the TPI is too hard to get off, what would you estimate labor wise? I checked the solenoid connection, and everything looks okay. I may just end up replacing both the valve and the solenoid while i have the plenum off. THANKS GUYS!! I hope to start driving this car (w/o worries) soon!
BTW its a 91' w 75k (AT)
